Temp guage sensor
Discussion in 'General RVing' started by Grinch, Sep 12, 2004.
  1. Grinch
    Grinch New Member
    Mr. Allisonman,
    I'm about to purchase a diesel pusher motorhome that has the Allison 1000 transmission. I would like to
    add a tranny temperature gauge. There are a few posts in this forum covering that topic but the
    responses are to install the temperature sensor in a "T" in the cooler line. My personal preference is
    to have the sensor in the pan but it does not look like there are any provisons for this short of drilling a
    hole in the pan.
    My question is....is there any problem with installing the sensor in the pan drain-plug hole provided
    that an appropriate fitting/adapter could be found to accomodate the sensor threads and the drain-plug
    threads?
    Thanks, Richard
  2. AllisonMan
    AllisonMan New Member
    Temp guage sensor
    Grinch,
    When you install a temp gauge you want to put it in the hottest oil temp spot which is "to cooler port". Unfortunatly I have yet to find out about a part number for a "T: fitting. I will call Allison and ask. Look for later posts and have a great day! :)
  3. Martin Brenneke
    Martin Brenneke New Member
    Temp guage sensor
    Has anyone come up with a part # for a T fitting to put a temp Sender in an Allison 5 speed 1000 trans? Or what size Fitting should be used to go to cooler?
  4. hertig
    Temp guage sensor
    Before I got my new truck with built in trans temp sensor, I got an external transmission filter with temp sensor built into it. If I were doing it in a motorhome, I'd see it that was appropriate.
