tires
Discussion in 'General RVing' started by dan 4880, Aug 19, 2006.
  1. dan 4880
    dan 4880 New Member
    i am about to replace the two front tires on an rv, the rv currently has tires with a F rating, do i have to use only F rated tires , or could i put on E rated tires without causing any problems?
  2. Grandview Trailer Sa
    Re: tires
    Depending of the weight of your RV, you may have to keep the F rating. They are 14ply where the E is 10ply. Compaire weight ratings stamped in each tire. If there is much difference, stay with the F's.
  3. ARCHER
    ARCHER Senior Member
    Re: tires
    I have always said you should stick with the same kind, type, size, etc., tire all the way around on your unit..... ;)
