tow vehicles
Discussion in 'Class A / Diesel Pushers' started by liljenn, Sep 9, 2007.
  1. liljenn
    liljenn New Member
    What is the best vehicle to tow behind your DP?
  2. DL Rupper
    Re: tow vehicles
    Do you want a passenger car? A SUV? A pickup? A sports car? 4 door or 2 door? An American vehicle or foreign? The possibilities are limitless without knowing your preferences. :eek:
  3. hertig
    Re: tow vehicles
    As DL says, you need to define 'vehicle' first.
    Once you have a class, then you can see what is 'best in (that) class'.
    In general, some brands, like Honda and Saturn, have had several towable models, many 4WD with neutral transfer case tow well, and other brands, like Toyota, generally don't tow well at all.
    The problem is the lubrication of the drive system when the engine is not running. Many cars which 'cannot' be towed, can be modified with an auxillary pump to allow it to be towed.
  4. *scooter*
    *scooter* Senior Member
    Re: tow vehicles
    I think the best one might be a real expensive import that someone gave to me as a gift...
  5. liljenn
    liljenn New Member
    Re: tow vehicles
    We want to tow a Toyota 4 runner 4WD that is a 2000 model. I know weight wise we can do this. We are also looking at other choices that are in the suv range. Thanks for helping.
  6. hertig
    Re: tow vehicles
    Be careful, Toyota has a policy of NOT producing cars to be towed. If you can do it at all, you will probably need to modify the vehicle (add a pump)
  7. liljenn
    liljenn New Member
    Re: tow vehicles
    How could I tell if it could be a towable? What qualifies something to be "towable"?
  8. C Nash
    Re: tow vehicles
    Check with Remco and they can tell you what mods, if any, you will need for the 4runner. Goggle remco
  9. hertig
    Re: tow vehicles
    The first place to look is in your manual, or the dealer. That will let you know what limitations the manufacturer puts on towing. Remco may be able to overcome these limitations.
  10. RustyFairmount
    RustyFairmount New Member
    RE: tow vehicles
    Why not purchase a used tow dolly and take whatever FWD vehicle that you want? I am provided a company car annually, so attaching a tow bar is not an option for me. And buying a dedicated car for RVing costs more than a tow dolly.
  11. hertig
    Re: tow vehicles
    Yes, a dolly or trailer is an option, particularly if you cannot modify the towed vehicle. Be aware of it's limitations, however. Make sure you are ok with the effort involved in getting the vehicle onto and off of the trailer/dolly. And never ever get into a situation where you need to back up; it will be most unpleasant.
  12. RustyFairmount
    Re: tow vehicles
    Good point. I suppose in an odd back-up situation, it would be much faster/easier to disconnect a tow-bar attached car than it would be to remove a car from a dolly, then remove the dolly.
  13. Shorty
    Shorty Senior Member
    Re: tow vehicles
    We've towed Jeep Wranglers for years without a problem...other than backing up, That's where a GPS system comes in handy when you've found yourself in unfamiliar territory not knowing where the road goes...
  14. GO BLUE
    GO BLUE New Member
    RE: tow vehicles
    BEEN TOWING A 4RNR SINCE 04 MODIFIED DRIVE SHAFT..........LOOKED AT PUMP....I WORK AT TOYOTA DEALER HAVE SEEN 3 PUMP FAILURES AT MY STORE IN 17 YRS......
