Re: Towing a Prius
Hi Mike2u I can only assume that it is a front wheel drive. If so I see no problem, I do tow on a dolly a 2000 Honda Accord with no problems. I also tow A4D Saturn. I asked my local police dept about needing a tag for the dolly, I was told it not required and I have been to SD to AZ with the dolly. I do recommend that each and every time you stop for gas you check the tire straps and tighten if needed. Oh almost forgot I did to add a 2x12x4 to the ramps to get the Honda to clear the cradle that the sits and rides in. Good luck with your decision. :laugh: :laugh: :laugh:
