towing honda accord with 40 allegro bus diesel
Discussion in 'Towables' started by allegrobusser, Jul 30, 2007.
  1. allegrobusser
    allegrobusser New Member
    do you really have to stop every 150 miles and put the automatic transmission through all 4 drive gears for 10 seconds each twice in order to avoid overheating the automatic honda transmission and ruining it?
    tx :)
    jj
  2. hertig
    Re: towing honda accord with 40 allegro bus diesel
    if that's what the honda manual says, than yes, you have to. Or they will not honor the warantee...
    You may be able to get an aftermarket pump installed which will overcome that. There is a company which specialized in that, but I don't remember their name. But its been mentioned at least 20 times in these forums.
  3. allegrobusser
    tx john, ill try to find out about it. :)
  4. Bush70
    Bush70 New Member
    the pump is made by Remco towing. However if you call them and tell them it is a Honda they will tell you that you don't need anything to tow a Honda. They are so sure they will even sell you an insurance policy if you are in doubt. Check it out.
    Good luck
