Towing
Discussion in 'Beginning RVing' started by motomom982, Dec 3, 2007.
  1. motomom982
    motomom982 New Member
    Will my 2003 Ford F250 7.3liter v8 power stroke pull a Raptor with a Spec. weight of 12,820Lbs?
  2. Grandview Trailer Sa
    Re: Towing
    A 2003 F-350 was rated for 13,400 lbs. Your F-250 is rated for LESS, but I am not sure what the rating was. Any way you look at it, you will be pushing the RATED load on your truck.
    To directly answer your question....Can you pull it? Yes.
  3. hertig
    Re: Towing
    For short distance, at slow speeds, on the flats, maybe. But in general? Perhaps not, as the rated 'towing weight' is for a completely empty truck, no accessories, no cargo, no passengers. Just a 150 pound driver and a bit of gas.
  4. benwd
    benwd New Member
    Re: Towing
    I think you would be very disappointed as, while capable structurally to do it, the performance will be miserable.
  5. Shadow
    Shadow Senior Member
    Re: Towing
    Agree with the others. You would tire of it quick.
