Travel trailer lift kit
Discussion in 'Talkback' started by shohoff, Jun 2, 2008.
  1. shohoff
    shohoff New Member
    does any one no how one would go about putting 2-3" of lift on a torsion suspenion? i hv a 26' Trailer Lite by r vision and would like to gain a little clearance. thanks
  2. Grandview Trailer Sa
    Re: Travel trailer lift kit
    There is no way to change the axles you have. Torsions are built with certain "degrees of angle". A "0" degree is the same as a 4" drop in spring axles. You might be able to block where the axles are mounted, but I don't know how safe that would be. The absolute safest way to change it is to purchase different axles with different angles built into them.
