TV antenna booster
sebaldwin
We just bought a 1997 Jayco Designer series fifth wheel. Does anyone know where to turn on the TV antenna booster? The wall plate is there with the coax outlet, the 12V plugin and the LED light, but the spot for the black switch to turn it on is blank. No switch is there. It's just empty. We've looked high and low for it to be somewhere else, but can't find it. The antenna doesn't pick up anything so it definitely needs the booster. We have a digital TV. Took it to the neighbors and hooked it to their RV antenna with the booster on and it picked up several stations. Didn't pick up any in our RV. Any suggestions on where to find the switch to turn it on??
akjimny
Re: TV antenna booster
In my tv cabinet there are a 12 volt power socket, a 120 volt ac wall socket, and an outlet for the tv cable with a small push button and led light. Led on equals power booster. If you have something similar I suggest you pull the cover with the led light and see if a previous owner might have removed the booster or otherwise screwed up the cable connection. As for repair service, I don't know if a regular tv guy could handle it or if it would have to go to a RV service center. Hope this helps some.
