I have a 06 Sunnybrook 32bksw. I have three areas where we can place televisions...living area, bedroom and garage.
In the living area there is a jack which consists of an antenna booster, coaxial jack and a 12 volt power source. 6" to the right is another coax jack..this one is for the cable TV.
The problem is that I have to switch the coax cable from one jack to the other when we switch from cable to the tv antenna in the living area. Secondly, I can only get the tv in the bedroom and the garage to work with the tv antenna...no luck with the cable.
I believe that this system is wired incorrectly and am looking for some help in resolving the problem. I find it hard to believe that Sunnybrook would not put the proper cabling in so that you could watch TV or cable without having to reconnect your coax to another jack nor leave out the ability to get cable tv in the bedroom and the garage.
Thanks for the assitance...a Sunnybrook wiring diagram would be great!
