valve saver
big bilko
In my coachmen mirada there is a filler bottle marked flash lube valve saver. It is a 450 mil clear bottle and is down to 150 mil. I have no idea with what to top this up withas my ford book only talks about brake fluid and coolant.Any help you can give me would be appreciated. Regards BIG BILKO :)
big bilko
Re: valve saver
Thank you Len, Most imformative. I will track some down tomorrow.I did not realise it was available in australia.The system must have been installed by the conversion mechanic when the r v was fitted out for the LPG . Thanks again Regards Big Bilko :) :)
brent
Re: valve saver
Hi Big bilko,
I know a lot about Valve Seat Recession and please do not use 2 stroke oil. You see it is not the carrier (Flashlube uses mineral oil) that does the work. It is the additives that protect that Valves and Valve Seats, Flashlube uses potassium.
What ever you do, do not use 2 stroke.
Regards,
Brent. By the way Flashlube is sold at all retailers SuperCheap, Repco, AutoBarn ect.
