I'm considering putting up 12 X 12 vinyl tiles - peel-N-stick behind my sink and stove. I know people have mentioned that they pop off when applied to the floor of the rv. Does anyone have any experience with them on walls? Thanks, Robin
Re: wall treatment I've put them on floors. The stuck ok, but shifted under use and made large gaps between them. On the wall I think they would shift from their own weight. Eventually. However, having said that, I think you could sort of 'frame' them to keep them from shifting.
Re: wall treatment They make rolls of self stick shelf paper that works pretty good. and its cheap enough that if it comes loose you just replace it. My wive has used it to redecorate around the stove and sink in older rigs that we have owned in the past.
