Want a Pick up - possibly for future towing.
Discussion in 'Towables' started by Cruzincat, Jan 24, 2013.
  1. Cruzincat
    Cruzincat Member
    Looking to get a used pickup, for light hauling( to the dump) and possibly for a future boat or RV Trailer. I can take a chance on an older truck, since I won't be towing anything heavy right away. In time, I can see how well the truck performs before I commit to an RV.
    I've been looking in Auto Trader for trucks but it is hard to determine what the towing capacities might be with the limited info. Is there a way to tell from the VIN#, what the towing capacity was when new? Or is there some other way to determine the capacity. Even if the seller has that info, I don't know whether I should trust it.
    Looking to spend under 10K. That's not much, but I am hoping with the economy and fuel costs, there might be some bargains out there. Is there a part of the country that would be better to look in?
  2. Cruzincat
    Cruzincat Member
    Someone local has a 2002 Ford F350 for sale with a 7.3L diesel, that looks promising. Aside from price and condition, after looking at tow ratings and seeing that a F250 and a F350, with drive train being the same, the tow ratings are identical. What is different between a 250 and a 350 that would be worth considering as far as pulling an RV is concerned. Is there another consideration I have missed?
  3. C Nash
    Just depends on what size rv you think you want. The 250 should handle most rv up to 35 ft IMO. The 350 will have a beefer frame, supension ect. The 350 is also probably a dualy.
  4. MO Dually
    MO Dually Junior Member
    A Ford F350 could be a Single Rear Wheel (SRW) or a Dual Rear Wheel (DRW) it does make a difference on towing. Generally if you are going to be pulling a fifth wheel or a gooseneck trailer then the Dually will haul a lot more due to the axle and tire ratings. If you are going to bumper pull, then there is little difference between a F250 (SRW) and a F350 (DRW). When in doubt refer to the towing guides, here is a link to Trailer Life's TG's, they breakdown all the possibilites.
    http://www.trailerlife.com/trailer-towing-guides/
    Most importantly, don't pull more than the truck is rated for, you are asking for trouble if you do.
    Be Safe!
