Weather radios??????
Discussion in 'Full Timing' started by parigi, May 31, 2003.
  1. parigi
    parigi Member
    Hi:
    Interested to learn which weather radios,fulltimers use,I'm in
    the process to be needing one soon and I'd love to learn as much as possible in order to make a wise and economical choice.......
    Thank you all,parigi.(new member and rver!) :)
  2. hertig
    I'd check out the 'SAME' radios at Radio Shack. They claim to only alert in the affected areas, rather than the entire area covered by that weather service.
  3. GLSmock
    GLSmock New Member
    My advice is this:go with a radio that is easy to use.I have a first alert radio and I am constantly looking for an active weather station that is fairly local.I would like to get one that all you do is turn it on.My Bearcat scanner does a better job and I use it a lot.Be sure to get a battery back up unit.GL
