weight of a 1986 prowler 20ft trailer
mabor59
Does anyone know how much a 1986 prowler travel trailer weighs approx.? I cannot find out how much it weighs anywhere on the metal tags attached to the trailer. Thank you, Mary
Grandview Trailer Sa
Re: weight of a 1986 prowler 20ft trailer
Mary, welcome to the forum. Look in the kitchen cabinets, maybe on the back of the cabinet door in front of the sink. There should be a tag with weights on it. You are looking for the UVW. That is the Unloaded Vehicle Weight. You will also see GVWR. That is the Gross Vehicle Weight Rating. That is what the axles and tires are capable of carrying. The difference between the two is what you can load in the trailer. Good Luck
