wheels/tires for and older RV
Discussion in 'General RVing' started by danev2, Jun 29, 2006.
  1. danev2
    danev2 New Member
    I recently bought a 1978 Harvest motorhome, dodge chassis (30ft/440/727TF)
    It has these 8.5x17.5 dually wheels.
    Now new 17.5 tires are $200!
    The duallies use the standard 8 lug bolt pattern of a 1 ton, but larger 5/8 studs.
    Are there wheels made that I can put on that have more common cheaper tires?
    Off a newer motorhome?
    It isn't going to be driven more that 150 miles.
    I plan on taking from SLC, UT to Fairview canyon and park it on some property I have. And leave it there.
    So I can't justify $1200 in rubber for it
    An ideas?
    thanks
    Dane V
    Layton, UT
    www.fordautowrecking.com
  2. rlmurraysr59
    rlmurraysr59 New Member
    Re: wheels/tires for and older RV
    Have you thought of hauling it to the location. Get a good sized truck and a lowboy trailer, strap it on and take it to your property. You can unload it, block it up and cover the old tires with some inexpensive coverings. Might even find a trucker that would haul it for you at a lower price than it would cost for the tires.
