Where is the antenna connector???? 1987 Winnebago
Discussion in 'Class A / Diesel Pushers' started by losangelespat, Aug 21, 2012.
  1. losangelespat
    losangelespat Junior Member
    Need some assistance...
    Have a Winnebago Chieftain 27, made in 1987.....
    Am trying to hook up my cable TV antenna through the existing roof connection....
    My problem is.... where is the termination on the inside of the Motorhome????
    Any help would be appreciated....
    LosAngelesPat
  2. Guest
    well i will give it a shot ,, where does the antenna come in ,, front or back ,, and also ,, do u have any compartments on the inside near the roof intrance to the attenna ?? this would help ,, i think i might know where the connection is ,, but first need to know where the cable is coming in ,, :)
  3. vanole
    vanole Senior Member
    Rod,
    I'm confused also. On my Dynasty if at a campground with cable their is a cable and phone conneection in the compartment that houses the power cord and reel.
  4. C Nash
    My connection is in the compartment where the power comes in 2002 HR Vacationer.
  5. H2H1
    I think all MH has that feature and is like all Mh in the compartment where the power cord is at.
  6. Guest
    well i agree with all of u ,, mine has the cable ,, phone and power cord all in the same compartment ,, maybe he will be back and let us know ,,, but i kinda think it is a one post ,, poster
  7. losangelespat
    Hello again.....
    Not a one-time poster...lol
    I know where it comes in on the newer MH's.... trouble is THIS is an OLDtimer....
    Yes... have an external box for Cable In/Antenna out.... that one's easy to find.... and it's not where AC comes in...
    It's the connector IN the home I can't find....
    The antenna feeds through the roof (and NO it isn't in the cabinet near where it comes in)... the antenna is a Crank-up Winegard... I think...
    I have found a DC cigarette lighter plug but no antenna connector near it....
    Does anyone know anyone who owns one of these ol' classic MH's ??
    Pat
  8. losangelespat
    OOOOOOOOO.... and the reason I didn't back to anyone... I forgot to subscribe to my own thread.... lol
  9. brad000123
    brad000123 Junior Member
    hi guys
    i am new here ,anyway nice question and others guide him nice hope he got there answer
  10. losangelespat
    I found it..... in the bedroom.... in ceiling..... doesn't do me any good.... lol
    At least I FOUND it..... thanks to those who tried to help...
    PAT
  11. wizard1000
    wizard1000 Junior Member
    I see this is an old post, so maybe someone will answer...
    We have a 1987 Chieftain 22 with the Winegard and outside connections but nothing on the inside we can find... Are you talking about the rear bedroom, or the front drop down?
  12. Clay L
    Clay L Senior Member
    There should be a Winegard wall plate with a switch, LED, and a coax connector. They usually put it in the overhead cabinet in the front. There may be a secondary wall plate in the bedroom for a rear TV. The Winegard bat wing antenna coax is connected to one of the three coax connectors on the backside of the wall plate in the front.
    Note that the circuit sends 12 volts up the coax to the amplifier in the antenna head when the LED is lit.
    Also the wall plate acts as an A/B switch. When the LED is lit the coax connector on the front of the wall plate is connected to the antenna and the amplifier is on. When the LED is off the RV park TV cable input that is in the service bay is connected to the coax connector and the amplifier is off.
  13. wizard1000
    In the lower dash panel, under the radio console...
  14. Stephany
    Stephany Junior Member
    To facilitate the selection of antenna cable connectors, 802 Connect provides the following connectors images and descriptions. When you order custom cables, please carefully study the pictures below to confirm that you order your cables are the cables you need.
  15. latricajames
    latricajames Junior Member
    The antenna connector devices are now so old for use. TP link connectors are now mostly used and much efficient for network speed.
