Where is the power converter?
Discussion in 'Talkback' started by TheShoeOS, Oct 23, 2007.
  1. TheShoeOS
    TheShoeOS New Member
    The power converter in my recently purchased 92 Terry 24C doesn't appear to be working and I can't locate it. Help!
  2. Kirk
    Re: Where is the power converter?
    Since Terry is a product of Fleetwood, look behind or inside of the electrical panel where your circuit breakers are located. That is usually where they put it. If not, trace the power cord as it is frequently located near there. If it has power you may be able to locate it by sound as most of them have a distinct hum.
  3. TheShoeOS
    Thank you. I didn't see it behind the panel the first time I looked. I'll check again and peek inside the thing.
    Regards
  4. hertig
    In my 2001 Terry, it was under the sink, mounted back against the wall.
  5. TheShoeOS
    Hey guys,
    Found it under the range of all places. Thanks for your responses nonetheless. Maybe this will help someone else save some time.
    TheShoeOS
