Won't start unless plugged in
Discussion in 'Class A / Diesel Pushers' started by Dale3, May 24, 2009.
  1. Dale3
    Dale3 New Member
    Have a 1993 Gulfstream Sunsport with a Chevy 454. It won't start even when jumped. Would not start even when jumper cables were hooked up to a running Ford V8 vehicle for 20 minutes. Disconnected jumper cables. Plugged motorhome into landline. On a whim I decided to try starting it and it started right up. Why wouldn't it start when jumped from another vehicle, but it would start when plugged into a landline?
  2. lrlong
    lrlong Junior Member
    Re: Won't start unless plugged in
    Sounds like a battery disconnect is open when not plugged in. Plugging in activated your converter, providing 12V to close the disconnect and/or ignition relays. just a wild guess.
  3. bbailey
    bbailey New Member
    RE: Won't start unless plugged in
    Check your ground cable from your chassis to your engine.Make sure it has a good conection.good luck
    brian
