Would like some tips !!!
Discussion in 'Class A / Diesel Pushers' started by mclane, Nov 9, 2008.
  1. mclane
    mclane New Member
    I just bought a 1991 Monaco dynasty, and I am a first time Rv'er, drove it from CA. to Tx. and perfect mechanical condition, but the coach does need some TLC wich I will do if I knew were to start looking, I need some gasquets for the wind shield and door and some compartments, they are all cracking pretty bad, were could I find these items and whats a good web site to get things for a 17 year old coach, thanks..........N.
  2. jetboat
    jetboat New Member
    RE: Would like some tips !!!
    most of the rubber trims and stuff can be ordered or bought at most trailer dealers, camping world, and even lowes.some times however youl have to find something close,and modify it to work.always carry a couple extra tubes of supper glue!.
  3. utmtman
    utmtman Senior Member
    Re: Would like some tips !!!
    You can also go to monacos site on the net and find the parts store and order direct from them.
  4. mclane
    mclane New Member
    Thanks a million, I have found the glass strips, so I will get on it asap..........I will check the monaco web site also, thanks.......N.
  5. murphy5856
    murphy5856 New Member
    Have a 1990 Beaver and I found all the seals at www.trimlock.com. My lower compartment took a Item # 100100B3X3 worked perfect. They have a lot of seals. Good Luck Ken
