Yet another question about towing from a rookie
Discussion in 'Beginning RVing' started by Roll, Sep 16, 2009.
  1. Roll
    Roll New Member
    Planned to pull the wife’s VW beetle behind the Bounder.
    Wanted to do four wheels down. The Beetle is manual shift (front wheel drive). Can't I simply put the Beetle in neutral and pull it?
    Need some advice. Trying to avoid buying another car just to tow.
    Thanks All,
    Roll
  2. scimedted
    scimedted New Member
    RE: Yet another question about towing from a rookie
    Hi Roll check your owners manual or talk to your dealer. I bought a honda stick shift and found out that honda said it could not be towed four wheel down and would cause damage if I did.
  3. LEN
    LEN Senior Member
    Re: Yet another question about towing from a rookie
    Again check with the owners manual as to the 4 down plus you must have the steering unlocked while towing(key to accessory). If this doesn't work a tow dolly would work.
