Re: 12V light bulb failure
If your battery is dead, you should replace it. Because of that, you have caused your converter to work overtime and have probably led to premature failure. Get a new battery and maybe your converter will last a little longer.
I also say get a voltage reading at the battery. If it is not correct, you may have to change your converter now, or you will ruin the new battery.
