If you've not done any research, you need to slow down and do so. Are you going to be full time? Are you moving a lot or staying in one place for a long time? Are you "camping" or "glamping"? What length? Do you want slides? So many decisions.
Look at floor plans. Lots of floor plans. Search the online sites: RVOnline, RVtrader & PPL Motorhomes are good. You can search by price & see what's available for the amount you have to spend.
One thing you definitely want to check is the age of the tires on any coach you're interested in. It's not a good idea to use tires that are over 7 years old & replacing tires are expensive but not nearly as expensive as a blow out can be. If possible, have an RV inspector go over the coach before you buy. A moho is complex to say the least! Not only do you have the chassis to worry about, you've got electric, plumbing, appliances, heating/cooling, furniture, everything that's in a stick & brick home crammed into a relatively small box. Lots to go wrong!
