2009 honda cr v
knotahog
I just got a new cr v to tow behind my hurricane class a , and am having a problem figuring out how to run the break away switch wiring thru the firewall, it is a small tight area to run the wires , I am not sure whether to drill a hole or if there is an existing hole thru the firewall. I installed a roadmaster bracket and a roadmaster tow bar and purchased a brake buddy. but no info on how other people went through the firewall. any help appreciated. Thanks, Terry
JimE
RE: 2009 honda cr v
On my Saturn there was enough room to squeeze it through the brake pedal penetration.
knotahog
RE: 2009 honda cr v
THANKS FOR THE INFO , I WAS ABLE TO FIND A RUBBER PLUG JUST ABOVE THE( I THINK )HEATER HOSES THAT PLUGS A HOLE RIGHT THROUGH THE FIREWALL, I RAN THE WIRES THROUGH THE MIDDLE OF THE PLUG INTO THE INSIDE OF THE CRV. OH I WAS ABLE TO DRILL A HOLE THROUGH THE RUBBER PLUG .
