2012 Wildwood Slideout schematics: help!
Sundance
I'm tring to replace a broken gear that drives the single rail slideout in my 2012 wildwood. Does anyone know where I could find schematics for this single rail under the sofa system? I just moved to Utah and the wilderness awaits! thanks in advance!
What about leaking plumbing or winterizing? Plumbing delete? Fridges are pretty finicky sometimes too. Leave it home? Propane accessories have caused some people fires. You could always get an enclosed trailer but what about the axles and bearings?
When installing an ARB air locker, you'll also be dealing with bearings—especially the carrier bearings and pinion bearings. Ensure that you have the correct bearings to match your axle model and gear setup. If you’re using a Dana 44-style differential, ARB may provide a wheel bearing kit specific to that axle, or you might need to source bearings from a third-party supplier (Timken, SKF, TBS, etc.) based on the exact axle configuration.
Back
