5th Wheel Pin Weight
hippity_hop
Is there anyway to determine the pin weight of a 5th wheel??
My present trailer sticker shows GVW 8,000 lbs. How much of this is pin weight?
Secondly if my truck can haul a payload of 1,000 lbs and can tow 8,600 lbs...does this mean I could haul a 9,600 lb trailer if the pin weight is 1,000 lbs.
I'm looking to get into a better truck but if my present truck is ok for the weight, and I'm not going to get much better fuel economy, what's the point!
Peter
Hi Peter, the pin weight can be found in the mfg. specs. generally its 10 to 15% of the trailer wt. but this is just a generalization. NO to your second question, your tow rating of 8600 is just that pin wt. included. What you have to look out for is if the truck has a payload of 1000 lbs, then a 5er with a 1200lb empty wt. pin wt, then your overloaded on your tuck even if the toal wt of the trailer is 8600 lbs. A thing to remeber is the mgf. pin wt will be for unloaded / empty trailer wt and will go up as the trailer is loaded with your stuff. :) :laugh: :cool: :bleh: :approve:
Just148
Try going to this site;
http://www.rvaa.com/articles/load_and_weight.php3
Peter
