86 skyline jamee reliability
lanceb
Junior Member
looking to buy an 86 skyline jamee 23' class c, it only has 56,000 miles, i'm curious on its reliability and if anyone knows about mechanical problems, thanks in advance
Welcome to the forum Lanceb. Not famalair with the Skyline but anything that old you can expect problems. Tires most likely need replacing even if treads is still there. need to ck tire dates of Mfg. Brakes, engine and all appliances should be checked good. Look for any water damage. If you can see it it will be a lot worse. Belts, hose will probably need to be replaced. Does the owner have service records? Are you handy with do it yourself?
JamesTheMan
Junior Member
It is best to have a professional or close friend look into this before you make any purchases. Best to pay a mechanic before you get yourself into trouble.
