88 Jayco Popup lift kit??
Bug
I just bought a 1988 Jayco (JayKing 6) pop-up tent camper in great condition. However, it does not have much clearance. So, I would like to know whether I can lift the box off of the axle 3-4". Does anyone have experience in putting a lift kit on one of these campers? Can you do it simply by placing blocks with a new "U" bolt. I have heard some say that you have to weld on a new "sub-frame" on a tent camper - is this true? Do some Jayco tent campers have an adjustment for ride-height that does not require a retrofit?
Finally - does raising the ride height of the box make the trailer less stable on the road?
Thanks in advance for any advice!! :approve:
Bug
I now have the answer to this post: For approximately $200, a welding shop will take off the existing axel and weld a new 3" tube in its place. They will then remount the axel on top of the new tube. That will raise the frame 3".
I still would appreciate any advise on whether or not lifting the frame effects the ride/stability of the camper?
Happy Camping :cool:
