97 f-250 power stroke
snowman71
I hope everybody is still alive and well since the last time i dropped in, I have a question or two to ask.
first off, i recently purchased a brand spankin new (for me) 97 f-250 heavy duty 4x4 crew cab short box power stroke diesel with 120,000 miles on it, I new the owner and it was his wifes truck, she drove it back and forth to work everyday, it was serviced every 3,000 miles. what sort of engine life should i expect out of the engine & transmission(e4od) it also has 4.10 gears.
I lifted it 4" and put 315/75/16 bfg all terrain tires on it.
my fuel mileage went WAY DOWN, im getting about 11 mpg around town, and not much better on the highway.
I also tow a 29ft tt weighing wet at around 10,000 lbs.
is anyone running the banks kit? or ats? I would at least like to change the air cleaner assembly, it looks like it leaks, does any one have any suggestions? thanks for any help given.
snowman71
redrattler01
Try going to: www.ftw.truckmoxie.com
Go to "Forums" then scroll down to "Performance Forums" then down to diesel. If you want to ask questions there, you will need to sign up as a member. If you don't, you can still view others questions and will prob find most of your answers in past post. It is a geat site for Ford truck owners.
