Re: 97 Fleetwood Bounder 34J Gas Tank Leak
Welcome to the forum. Even if there was a recall you will get no help from Fleetwood as the Fleetwood then is no longer. Most likely is a hose or sender unit leaking. Does it only leak when Ful? If so probably where the guage sender unit is. If all time probably hose or fitting. Drain all the fuel out you can. Do not have a droplight where any spilled gas can spill on it. Be careful of static elecricity. you will need a jack of help to lower the tank. If using a jack use a board, plywood ect to support tank. May have to lower enough to get to top and disconnect lines before droping all the way. Good luck.
