kevinfromwebb
Hey, got a simple question I think... I've got a 24 ft bumper pull that I bought in spring '02... I noticed this weekend that if the trailer is plugged in to the truck and the truck was running or key turned on, the 12v dc seemed to work fine, ie the lights would work and you could turn on the water pump to wash your hands etc... If the truck was turned off or unplugged from the truck alltogether the 12v dc wouldn't work... The battery 'guage' on the inside of the trailer showed the battery was fully charged and the connections to the battery seemed to be tight... Does this sound like a loose wire or ground or would it be a switch or relay??? Maybe the battery???
Everything worked well plugged in to AC and I keep it plugged in to AC in the back yard while I'm not using the trailer...
Just thought maybe yall had this problem before or could point me in the right direction...
Thanks,Kevin
Thanks,Kevin
