advice needed truck size for fifth wheel
peleger
my wife and i just purchase a used 1993 265 jayco in
december,always had trailers but kept on season lots
this is going to be a new experience for us ,i need all
the info i can get to purchase the best truck.at first we
do not plan long haul but i know we will in a few year.
thanks
paul
Hello Paul,
It would help to know the Jaco's loaded weight. I would buy at least a 3/4 ton with towing pagage. I like the 460 ford and 454 Chevrolet engines but, the 351 or 350 will probably tow the Jaco with the proper axle ratio. If you are thinking diesel the ford p/s, dodge cummings or 6.5 chev turbo should do the job. Most prefer the ps ford. If you are looking at new, I would look at the new chev duramax. Lots of good reviews but, it has not been out there long enough to prove itself. I personally like the duallys for towing even the smaller trailers because of the handling and stoping. I tow a 28 ft cougar, that the factory recommends you can tow with a 1/2 ton, w/slide with a 6.5 chev dually. Towed it with a 1/2 ton and never felt confortable. Over buy on towing, you will probably be getting a larger trailer in a couple yrs anyway. Good luck
Chelse L. Nash
fulltimer03@yahoo.com
