I have an interesting one that maybe some of you have seen before.
01 GMC Sierra 2500 HD 8.1L with Allison 1000 5 spd.
Intermittent temp gauge readings. Usually only as transmission is warming up.
One morning I started the vehicle and within 10 seconds the warning came up that said Trans Temp Hot / Idle Engine.
Other times it does the same as I drive about 2 miles from home in the morning.
If I let trans warm up then shut off engine and start again sometimes it will register normal and other times the gauge will not register.
As this happens I will sometimes get an MIL and code 7000 & 7012.
Seems like a bad connection somewhere or bad temp sensor.
Where is the temp sensor?
I unplugged the 20 pin main wire harness from the back of the transmission and there was oil in the connectors.
I did the best I could to clean everything up and put it back together.
I will see if this solves the problem.
