allison 5 speed won't go into 5th gear
fixit
Junior Member
i have a 05 monaco and my check trans light comes on and when it does my trans will notupshift up to 5th gear. i have had the tcm and the ecm checked. the ecm says im ok but the tcm says when iwant to upshift i am asking the engine to slow down a little and the tcm gets no response? so the tcm won't shift to 5th. gear
Go figure?
Any clues?
dbarton291
RE: allison 5 speed won't go into 5th gear
fixit - 6/2/2010 2:38 PM
Go figure?
Any clues?
What's the diagnostic code list in the TCM read out? If you had it checked out, that's the first thing the technician should tell you.
