the transmission i purchased was removed by a butcher...lol.. the wires were cut right at the sensors, the modulator was chopped off at the vacuum fitting, the oil hoses were simply cut as well... thanks for the info, after several hours of research last night i found the modulator location and what was left of it on the transmission, i can run the transmission either way, with a vacuum modulator or cable operated, the price of parts will end up being about the same, just shy of $200, the vacuum set up is more complicated / harder to install so i am curious as to what system works best... Vacuum or cable.
the transmission is the "rare" mt 643R with retarder....low miles and only $200.. its all going into a 1977 AVCO motorhome that is also being converted to 4WD.
Eric
