I saw a thread on here from allisonman I think, and I had a question. Not necessarily RV related, but I don't know where else to turn. I have a '97 Ford dump truck running a machanical injected 8.3 cummins that currently has a 600 series tranny. I'd like to switch over to a 3060 but not sure what all needs to be done. If I get the tranny with the computer, I've been told I'd only need to add a throttle position sensor. Is this correct or not. I have a 3060 in another dump truck and like the lock up it has. The 600 series just seems to slush away through the torque converter until you get to the final gears for lockup. As I'm usually under pretty good loads, this tends to heat the tranny fluid and I fear it won't last too long, plus the 3060 holds almost twice as much fluid.
Thanks in advance.
Jim
Thanks in advance.
Jim
