Allison Temp.
hobo
What should the Temp.run on the transmission? Mine runs 185 to 190 most of the time.The fluid is clean.If this is the wrong temp.what would cause it to run warm.
Re: Allison Temp.
Allison said don't even think about temp until it is over 215 and then think about it.
dbarton291
RE: Allison Temp.
hobo - 2/15/2008 11:49 PM
What temperature are you reading? If it's the fluid going to the cooler, max is 300. You will see a temperature sender in the fluid line going to the cooler. At 300 deg F, Dexron starts to break down very quickly. If you're reading sump temperature, like some World Transmission setups do, max is 250 deg F.
G
Guest
Guest
Re: Allison Temp.
I agree with gts .. my MH runs lower 200's when pulling a hill with a toad ,, but most of the time around 180 or so on level road ,, ,,
Don't worry about it,, till it says ,, pull over ,, u gotta walk now ,, hey i'm JK :eek: ;) :laugh: :laugh: :laugh: :laugh: :laugh: :clown:
