RE: alternative propane heater
Hi, John
Just a thought
; CO is a heavy gas
, and would settle to the floor then build up :dead: .
If the O2 sensor is in the heater and it is mounted on the wall higher then your head.
You may not have enough Oxygen, and the Heater’s sensor would not know it :dead: :dead: :dead: .
Maybe the heat rising would mix up the air so this would not happen, but I don’t know :8ball: :8ball: .
AS the “Texas Clodhopper†said, it will “use the oxygen†:approve: :approve: , and because it is cold all the windows and vents will be closed. The combustion by-product has nowhere to go, i.e.-CO and water :angry: :angry: :angry: . The water will condense on your windows
. For myself, I would be very leery any “combustion heater†that was not vented to the out side.
:blush: :angry:
(JMO)
What I would question is WHY? :question: :question: :question: :question:
This item is not for sale in the state of California. Customers are responsible for checking local codes and regulations prior to purchase.
Good luck
:clown: :bleh:
:laugh:
:shy: :shy:
