Allisonman I have retired a 1999 international schoolbus and want to turn it into an rv the problem Ihave with the tranny is that between 20-26 mph the trannt wants to shift back and forth between the gear it was just in, to the next gear. When I mean hunt and shift i mean it sounds as if the u-joints are going to be twisted out of the dang thing,its not a gentle hunting it is more like a gorilla with a club hitting the bottom of the floor. I have owned buses for a while and this is the first I have had of this problem with a 545.I have heard that if there are any air leaks in the turbo sys it would effect the shifting or if the throttle positioning switc on the accel pedal is bad this could be the problem of if the highpressure oil pump/fuel pump was going bad this could be a cause the tranny does not leak and if you go ahead and drive this thing like you are mad at it the hard shifting and the hunting is not as bad.before i spend any money i dont have what would you suggest to look for first before going to the local allison shop?any help will be most appreciated.
