Re: Atwood 8500 furnace problem
Hi Dick and Welcome....
RV thermostats are, at best, 10%+/- on accuracy......so that is a lot of latitude for error in temp.....if you can shut off the unit with by moving the temp setting to a lower temp than that is what you are going to have to do....or replace the stat....
When an RV thermostat shuts off.....It removes power to the furnace controls.... if everything else works then it is not a circuit board...it is the Stat....
