I have a 1988 prowler regal fifth wheel. It has two ducted hydroflame 8520 series II furnaces in it. The one in the rear works fine but the one in the front will fire when on first cycle most of the time and run until thermostat shuts it off. But when it is started again it will fire and run for about 20 seconds give or take a couple of seconds and the burner will shut off but the fan will continue to run. if I turn the thermostat off and wait a hour or two and try it again it will work but then it does the same thing. I can see a daubers nest in the burner area but I am not for sure how to get to it to clean it out I am mechanically inclined but just never took one of these apart.
CAn anyone help me with diagnoises. I think it could be the limiting switch. Does anyone have a technical service manual for this model furnace?
thanks,
charles
thanks,
charles
