Atwood Water Heater
mulerider
My 6 gal water heater fails to ignite the intermittent ignition. It goes off when the water is hot and stays off. Anyone know what my problem could be?
Atwood Water Heater
Sounds like the thermostat. I would replace the thermostat and ECO valves first (about $15-18 a set). They are easy to replace, but make sure you put the foam insulation on that comes with them. If you have trouble doing it, send back a note or email me. I've replace mine and another friends and water heater works fine (similar problem to yours).
good luck and welcome to the forum.... ;) :)
mulerider
Atwood Water Heater
Archer: I did exactly as you said and my water heater is working fine now. Thanks for your help.
