Awning Repair...
John that is exactly what I did also, my rip was right under the gutter where it attaches on the end the manafacturer had a screw in the end to give it support which I removed first, and I was able to pull the awning out of where it was connected and I sewed it back togeather with a wax thread,then I took a very small drill bit and drilled some small holes in the bottom of the gutter,I was able to tamp it back in with a blunt piece of wood and then I sewed it again using the holes in the gutter to give it more support knot tying it each time I made a loop through the gutter, then I cut apiece of that clear awning tape and put over it, once I got that finished I took some some awning and tent spray waterproofing and sprayed it all and after I got my awning all washed real good I sprayed the whole awning with the water proofing top and bottom.
It seems as it will hold just fine. Later Jim
