Batteries & Chargers
Swede
Since the charger topic has been fairly well covered, I'd like to comment on solar panels.
Solar panels are really NOT a waste of time or money. They do require some planning for their proper use, but the proper panels can completely recharge a battery (or bank of batteries) within a day.
The key to recharging is matching the panels to your batteries and the usage you give them.
I use a 5 watt panel on my fishing boat. It keeps the trolling motor battery recharged without use of external charging. I also use 2 15 watt panels to maintain and recharge 2 80A/hr deep cycles that power my radio transmitting equipment for emergency communications and networking.
The 5 watt panel you mentioned would only just barely maintain your batteries against the drain from your LP leak detector and other minor electricity users. 2 15 watt panels, however, provide approx. 2 amps of charge current during full sun. This would bring your batteries back from a 1/2 charged state within a full summer day. If your battery usage is draining your batteries below 1/2 charge, or you have more than 2 batteries, a panel rated at 50 watts (or greater)would be recommended. Of course if you really want a speedy recharge, panels rated at 100 watts, and higher, would fit the bill but are rather pricey. Be sure to use a charge monitor with ANY solar panel. It keeps the solar charger from overcharging your batteries.
Personally, I would spend money on solar before spending it on a generator if your only need is to recharge your batteries. It's quieter, you don't have to carry extra fuel, and (the best part) they work even when you forget about them.
WW
