Re: Battery bank 12V vs. Inverter 120V connection
Don't do that WHILE you are connected to the local utility!
Otherwise, build you a box with a 30 amp connector on it just like at a campground. Plug your regular extension cord into it, and you now have 120 AC for your trailer.
However, you better watch what is already connected to that 120 inside your trailer. Maybe a water heater or a converter.
You didn't mention the wattage of your inverter, but it won't power much. I hope it's a good one, too, so it will have a good waveform and frequency. Make sure it has a good fuse/breaker, so you won't burn your trailer down to the ground while your sleeping! :dead:
