Battery charging
kegman
I charge the batteries in my travel trailer using a 10a 12v automatic charger driven by my 1500w generator. It charges at 14+volts. Should I disconnect the batteries from the trailer's converter prior to charging from the external charger?
FogNobber
Battery charging
I do the same thing and have never had a problem even when the trailer is also plugged into the generator and the converter is on.
Battery charging
There should be no problem in what you want to do as I know of no converter that is not protected from reverse current. This is pretty easy to do as all that they need is a bolocking diode in the output. The reason that they have it is due to the fact that all modern RVs have the ability to charge the house batteries from the tow vehicle or the chassis. That supply will range up to 1V above the converter voltage so it has to be protected.
