Best towing speed?
quote:when I tow at the speed limit (usually 70 or 75), my gas mileage drops to 8 MPG,
When I firest began to travel via RV, the service manager at the local dealership told me that a good general rule for fuel consumption for any heavy rig is that once you reach the optimum speed for conservation, in most cases around 50 mph, each time you increase speed by 5 mph you will decrease the mpg by 10%. He said to figure this from whatever mpg you get at 50/55 for whatever you are driving and/or towing. In more than 30 years of RV travel I have found that to be pretty much true. With some of the modern RVs the optimum mpg is reached at a slightly higher speed, and the terrain you are traveling through will also effect the speed of greatest efficiency, but the rule is still a good guide. If you use that rule, then your mileage being 8mpg at 70, the figure backward to 55 you have to expect to get near 11mpg. I suspect that figure is pretty close. High speeds cost fuel in all vehicles and the big block engines we use for our heavy RVs are at the top of the consumption.
