This may also help
ISSUE:
Some 1999-2004 F-53 Stripped Chassis vehicles equipped with a 6.8L engine, may ingest water into the air filter while driving in the rain. This can cause loss of power and/or engine stumble.
ACTION:
Replace the air cleaner inlet tube with a revised tube and strap. Refer to the following Service Procedure.
SERVICE PROCEDURE
Remove and discard existing shield. 2002-2004 model year vehicles are equipped with a long shield (Figure 1) and 1999-2001 model year vehicles are equipped with a short shield (Figure 2).
Figure 1 - Article 04-24-22
Figure 2 - Article 04-24-22
Remove and discard the existing air inlet tube. To remove, grasp the air inlet tube at the bottom of the air cleaner assembly and pull downward.
Remove and discard existing retention strap.
Install revised air inlet tube into the bottom of the air cleaner assembly and secure with revised strap (Figure 3).
Figure 3 - Article 04-24-22
PART NUMBER PART NAME
XC3Z-9F843-AA Air Intake
XC3Z-9E618-AA Strap
