I have a new 2014 Thor Windsport with a TV located in a compartment outside. While at home, I was doing my monthly generator check so I while I was running the generator, I turned on the outside TV. After letting it run for a 1/2 hour or so I turned off the generator. The outside TV went off when the generator was turned off and now it will not come back on. All the outlets both inside and outside, lights, inside TV's and everything else is working fine. I have checked all the breakers and the fuses. I have tried to get to where the TV is plugged in from the inside (behind a bathroom cabinet) and have taken the tv loose from the outside and can't get to where the power for the TV is coming from. Hopefully the outside TV isn't fried-have never had any problems with it before. Any advice would be appreciated.
