Convert 30 amp to 50amp????
Hello,
Id be curious to better understand what you mean by 'Border line'. You may be right, but is this by experience of tripping breakers or just knowledge that all the accessories you run make it marginal. If it is just knowledge and you are NOT tripping breakers - my reply would be 'so what' - it isnt a problem so dont 'fix it'.
The idea of a separate circuit for the A/C may be a good choice. This would isolate the A/C from the remaining circuts.
I dont think you would need to rewire the whole rig as each circuit is wired for its intended max load - if you dont overload the particular outlets, the outlets will not see any additional load regardless of how much power is available.
I would think that the main line to the circuit breaker box would need to be increased to carry the additional current if and you will need to add a breaker (or possibly replace the breaker box) to accommodate the higher current. You may have a limit of 30 amps on the breaker box and need a 50 amp box.
There is likely a separate circuit for the A/C and perhaps this is the one you might want to increase if it is tripping. Changing a breaker may void your warranty for the rigs electrical circuit, so you want to be careful here...
Bruce A. Wittmeier
Home:
MikeBrandn@aol.com
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, Chrome Step, Line-X bedliner, Reese 16K slider, Jordan Ultima 2020, AirLift Airbags, Sunnybrook 30RKFS
