parksoffroad
In April of 2000 we took delivery of a Jamboree 29ft class C motorhome. It was a "new" vehicle with a floor plan that we had ordered. We had some small problems that we had taken care of and all seemed good.
After a few years, we started to notice that as the fiberglass siding of the motorhome was fading that there were areas that remained very white. This gives the RV a splotchy appearance, not very attractive to look at. It is embarrasing to pull into a RV park in a "new" RV and have the RV look splotchy and uneven in color.
We contacted the Morgan Hill Dan Gamels to see if they could fix the problem. They tried to buff the areas out but only succeded in adding swirl marks to the RV. They told us to take it back to the Dan Gamels Fresno RV Center where we purchased it from.
We took it back to Dan Gamels Fresno center and they talked to Fleetwood and said that the areas in question had been damaged and repaired and that was not covered under warranty, so they denied the claim.
They had also sold us a MVP warranty that was supposed to cover items such as fading, but again they said that is was damage and that was not covered. We also then found out that the warranty has a $1000 liability limit, and does not cover gelcoat fiberglass. The only part of the RV that is not gelcoat fiberglass is the nose (doors, hood and front fenders). We paid $1795 for this warranty! Who would pay $1795 for a $1000 warranty? We would not have had we known!
You can see the front and back of the actual warranty on these links: (click the box in the lower right corner of the picture to enlarge it)
http://www.parksoffroad.com/mvp front.jpg
http://www.parksoffroad.com/mvp rear.jpg
As I have stated over and over again throughout this process: WE HAVE NEVER HAD ANY DAMAGE OR PAINTING DONE ON THIS RV! We thought is was a new RV but it was apparantly damaged at some point and reparied. We dont know where or when, but it was before we purchased it from Dan Gamels in Fresno.
We have tried to work with the dealership and Fleetwood for quite a few months and have now retained an attorney. I will let everyone know how it works out in the end.
Please dont let this happen to you! Take the time to read the fine print even if it takes you an extra hour. I would also recommend checking with others about a dealership before you put your trust in them. If we can prevent this from happening from 1 other person I will be happy!
